nyrngrz Posted September 9, 2020 Share Posted September 9, 2020 I have a 2003 Holiday Rambler Vacationer which has a Sharp R-820BK microwave convection oven. I have replaced this unit previously with ease, but it looks like I have to replace it again and wonder if anyone has replaced their unit with another make/model without any modifications? It was quite easy slipping the same model into the slot and am hoping to do the same. Thanks. Link to comment Share on other sites More sharing options...
thomasgibbens Posted September 10, 2020 Share Posted September 10, 2020 We replaced our Sharp unit with a GE and are pleased but did have to modify the opening. Take a close look at how the door opens. The Sharp model did not add to the overall width of the unit but the GE added almost 2” to the required width. Tom Gibbens ’15 Dynasty Link to comment Share on other sites More sharing options...
biloxi_dad Posted September 10, 2020 Share Posted September 10, 2020 I have a 2005 HR Ambassador with Sharp micro/Convection oven that only ran 1 min on Convection...found it was a part that cost about $25. Replaced 2 yrs ago and it still working properly. You have similar problem? 1 Link to comment Share on other sites More sharing options...
rudisill99 Posted September 10, 2020 Share Posted September 10, 2020 2 hours ago, biloxi_dad said: I have a 2005 HR Ambassador with Sharp micro/Convection oven that only ran 1 min on Convection...found it was a part that cost about $25. Replaced 2 yrs ago and it still working properly. You have similar problem? The same thing happened with mine. It was a $25 "damper motor". 1 Link to comment Share on other sites More sharing options...
biloxi_dad Posted September 10, 2020 Share Posted September 10, 2020 Yes, the damper motor. John & JRT Cody 2005 HR Ambassador w/ Jeep Wrangler toad Link to comment Share on other sites More sharing options...
Guest Tim503 Posted September 14, 2020 Share Posted September 14, 2020 I replaced mine with the Dometic from Camping World but had to put in a shelf. It is terribly noisy but it was a couple hundred dollars so the price was right. It has the exposed heating element on the ceiling. It does have a fan for convection mode or use it as a broiler/grill for steaks. I ended up with 6" on the side of the oven. Perfect for half gallon bottles. Link to comment Share on other sites More sharing options...
Hancoman Posted June 6, 2021 Share Posted June 6, 2021 Have the opposite problem convection works microwave doesn’t Link to comment Share on other sites More sharing options...
