Ivylog Posted October 8, 2020 Share Posted October 8, 2020 These steps are used on 07-09 Monaco Sig. EXe and Dynasty plus Beaver Marquis. Not a great idea to use ball beating slides where dirt can get into them.Bottom ball bearing slide on my double steps (Coach Step Inc)’ needed replaced as the steps would not close without some help... slide bent and ball bearings missing on one side. Another member posted that the 500lb slides were Knape & Vogt Kv8900 B22 22” ...$109 for 2 on EBay instead of that much for one from Monaco. Getting the steps removed was not too bad...removed by myself and only 6 bolts and several plugs. Had already built gravel ramps to get the MH higher having replaced the oil pan. Used a sharp chisel to remove the pop rivets plus a 1/8 Allen to remove 2 small bolts. The new slide was an exact replacement... no drilling. The new slide has a center recess (2nd picture) so there really isn’t any reason to remover the steps from the MH... all pop rivets can be installed from the outside unlike the one I removed.Had a little help getting the steps back in by myself. Did pressure clean the other 3 slides while I had the steps out. Naturally I decided to enclose the bottom and back of the steps after putting them back in... would have been easier when I had them out. Hopefully enclosing will keep most of the dirt out that clogs the slides. Fortunately it was still on the ramps so getting underneath was fairly easy. Bought 2 $6 plastic sign boards (19X24”) at H D. Used the metal legs to pin the 2 boards together and taped them together. Cut it down to a 30.4X24” piece so it would slide in on top of the 2 angle iron cross braces. Taped it in place and put the 8.6X24 piece across the back and taped up the 6” hole at the back...needed a 30” piece to fill completely. Painted it black not that you can see it. 1 Link to comment Share on other sites More sharing options...
Ivylog Posted October 8, 2020 Author Share Posted October 8, 2020 (edited) Coach Steps is now Lippert. Edited October 8, 2020 by Ivylog Link to comment Share on other sites More sharing options...
Paul A. Posted October 8, 2020 Share Posted October 8, 2020 6 hours ago, Ivylog said: These steps are used on 07-09 Monaco Sig. EXe and Dynasty plus Beaver Marquis. Not a great idea to use ball beating slides where dirt can get into them.Bottom ball bearing slide on my double steps (Coach Step Inc)’ needed replaced as the steps would not close without some help... slide bent and ball bearings missing on one side. Another member posted that the 500lb slides were Knape & Vogt Kv8900 B22 22” ...$109 for 2 on EBay instead of that much for one from Monaco. Getting the steps removed was not too bad...removed by myself and only 6 bolts and several plugs. Had already built gravel ramps to get the MH higher having replaced the oil pan. Used a sharp chisel to remove the pop rivets plus a 1/8 Allen to remove 2 small bolts. The new slide was an exact replacement... no drilling. The new slide has a center recess (2nd picture) so there really isn’t any reason to remover the steps from the MH... all pop rivets can be installed from the outside unlike the one I removed.Had a little help getting the steps back in by myself. Did pressure clean the other 3 slides while I had the steps out. Naturally I decided to enclose the bottom and back of the steps after putting them back in... would have been easier when I had them out. Hopefully enclosing will keep most of the dirt out that clogs the slides. Fortunately it was still on the ramps so getting underneath was fairly easy. Bought 2 $6 plastic sign boards (19X24”) at H D. Used the metal legs to pin the 2 boards together and taped them together. Cut it down to a 30.4X24” piece so it would slide in on top of the 2 angle iron cross braces. Taped it in place and put the 8.6X24 piece across the back and taped up the 6” hole at the back...needed a 30” piece to fill completely. Painted it black not that you can see it. Thank you for this great post. A real problem that many have encountered. Link to comment Share on other sites More sharing options...
granvillebarker Posted October 20, 2021 Share Posted October 20, 2021 Thanks as well, these are also on 05 Dynasty’s. Link to comment Share on other sites More sharing options...
