Replaced Marker lights with LED's
cpat_39
 Share
Recently replaced all marker lights with Bargman #59 LED lights. Total of 12 lights. Yesterday the 20 Amp fuse for the markers blew. My research says the LED bulbs are about 10-15% lower voltage than the older incandescents.  Other than wiring issues that I still need to explore any thoughts on why fuse would fail?
Pat C
It has to be a wiring issue because 12 replacement 12 volt LEDs use 85-90% fewer amps than the 12 12V incandescents  they replaced.
I replaced all my lights with LEDs and have had no problems with any fuses. I would look at each marker lights wiring and connectors. Make sure that nothing got pinched or damaged.
 Share
