dandick66 Posted October 26, 2020 Share Posted October 26, 2020 My RV Comfort .ZC thermostat has been acting weird. It was not allowing me to select certain zones and then it showed the set temp in 1 zone was 161 degrees. I reprogrammed the thermostat and then I received the AC and Aquahot diagram from REV (attached). I also emailed Airxcel/Coleman but they really weren’t a lot of help. I have 3 AC units with heat pumps and an Aquahot. There are 4 zones. If you look at the diagram it indicates that zone 4 is the “AC Brain”. I have no idea what that means. Three of the zones make sense and I programmed them to AC and Gas and Electric heat. Zone 4 has me really confused. The drawing indicates that zone 4 is only the water bay heat from the Aquahot. However, there is a thermostat for zone 4 in the rear bathroom. I programmed zone 4 to only have “Gas Heat”, no AC or eldest. I don’t know if this is correct or not. Does anyone in the group have a similar setup to mine? If so, please look at your thermostat model 8330D331 or 335 and tell me how each zone is programmed. I originally thought my thermostat was defective so I went to the Airxcel/Coleman site and it indicates the thermostat “repair parts only”. Coach is a 2012 Diplomat 43DFT. Dan 2012 Diplomat Heat&AC.pdf Link to comment Share on other sites More sharing options...
