Guest terry05dip Posted March 8, 2021 Share Posted March 8, 2021 Here are a couple of photos with my problem. Molding that the slide topper is attached is pulling away. It seems to be riveted. Any suggestions on how to repair. Link to comment Share on other sites More sharing options...
Mark B Posted March 8, 2021 Share Posted March 8, 2021 (edited) Look at YouTube azexpert. He does lots of roof inspections and repairs. Looks like the screws or rivets have broken. It appears to be not that uncommon. You may have to take the topper off and add more screws, reseal and put the topper back on. Edited March 8, 2021 by Mark B Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted March 8, 2021 Share Posted March 8, 2021 It's not going to be easy. It shouldn't be rivets, it should be screws into the top metal framing of the side panels where the roof and side panel meet Those screws rust and break behind the removable rubber piece on the molding. I replaced all of my roof screws with SS self-drilling TEK screws. To get to area of separation, first you have to lock the spring on the roller, remove the topper roller and lay it on the roof, bring in the slide to make access to the screws easier. Don't let water run between the trim piece and the roof. It will delaminate the plywood from the outside panel. I've been down that road. That is why you have to check the caulk on the top of the trim piece regularly. I'll get back to you with the SS screw size. Gary 05 AMB DST Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted March 8, 2021 Share Posted March 8, 2021 Terry, Look in the downloads section of this forum. Look under exterior, a write up about this is there, and it may help. Link to comment Share on other sites More sharing options...
Guest terry05dip Posted March 8, 2021 Share Posted March 8, 2021 The moulding seems to be of a hard substance and painted to match the coach. If it is a rubber piece how do you not damage the paint? Ray. Sorry. Went to download and found. Good information. Thank you Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted March 9, 2021 Share Posted March 9, 2021 Terry, I used a utility knife and scored the paint on the top and bottom seam. I used #10-16x1 SS self drilling screws. Link to comment Share on other sites More sharing options...
