Duanebalogh Posted March 9, 2021 Share Posted March 9, 2021 Our passenger bedroom slide on our 2006 monaco excitive goes out fully on top but the bottom still lags about an inch more. How can we adjust it to go out completely Link to comment Share on other sites More sharing options...
96 EVO Posted March 9, 2021 Share Posted March 9, 2021 Is it cable driven? Link to comment Share on other sites More sharing options...
Duanebalogh Posted March 9, 2021 Author Share Posted March 9, 2021 Not sure. Is the mechanization under the bef Link to comment Share on other sites More sharing options...
RON CLARKE Posted March 10, 2021 Share Posted March 10, 2021 I have a 2006 Monaco Windsor w/ bed on driver side slide. when extending or retracting , I have best luck if I pick foot end of bed up, then move the slide. you may also find the attaching bolts (under the “platform under the bed) need to be tightened. Ron Clarke Link to comment Share on other sites More sharing options...
96 EVO Posted March 10, 2021 Share Posted March 10, 2021 4 hours ago, Duanebalogh said: Not sure. Is the mechanization under the bef Easy to see if it's cable driven on the outside when the slide is extended. There will be 4 cables (2 per end), going thru holes in the seal, to the outer wall. 4 hours ago, Duanebalogh said: Not sure. Is the mechanization under the bef Your bed is attached to the passenger side slide? Link to comment Share on other sites More sharing options...
Duanebalogh Posted March 10, 2021 Author Share Posted March 10, 2021 No you can not see the cable outside cause it's got a full cover on the bottom of the slide Link to comment Share on other sites More sharing options...
96 EVO Posted March 10, 2021 Share Posted March 10, 2021 Ok. Many of the Monaco models have a cable driven passenger side bedroom slide. Usually just contain a wardrobe, and the bedroom tv. Link to comment Share on other sites More sharing options...
Chargerman Posted March 10, 2021 Share Posted March 10, 2021 (edited) I have an 06 Exec also. Your curbside slide should be an HWH X brace mechanism. They are wall mounted on the inside. You can see them by removing the wide verticals wood trim on the slide. I’m thinking that yours may have come detached from the wall on the bottom. Kind of painful to get to as it’s a bit tight. They didn’t put in many bolt at the factory and yours may have come loose or stripped. You can replace the screws and add more in the holes that are not used. There is not a top to bottom adjustment on this system. There also is not a up and down adjustment. To adjust height your have to remove the bolts and Jack up the slide and rebolt. Take a look and let us know what you find Edited March 10, 2021 by Chargerman Link to comment Share on other sites More sharing options...
Duanebalogh Posted March 10, 2021 Author Share Posted March 10, 2021 Thank you, we'll check it out tomorrow and let you know Thank you all, we'll check tomorrow. Great advice Link to comment Share on other sites More sharing options...
Duanebalogh Posted March 11, 2021 Author Share Posted March 11, 2021 How do you take the vertical wood strips off to expose the slide in the bedroom mechanism to fix it Link to comment Share on other sites More sharing options...
Chargerman Posted March 11, 2021 Share Posted March 11, 2021 they are held on with some very strong Velcro and mine had one screw at the very top screwed in from behind. Use a small mirror to see if you have a screw on the top. Then pull on it carefully but firmly, working top and bottom Link to comment Share on other sites More sharing options...
Duanebalogh Posted March 11, 2021 Author Share Posted March 11, 2021 Thank you will try that and get back with you how it works Link to comment Share on other sites More sharing options...
Duanebalogh Posted March 14, 2021 Author Share Posted March 14, 2021 On 3/11/2021 at 10:48 AM, Chargerman said: they are held on with some very strong Velcro and mine had one screw at the very top screwed in from behind. Use a small mirror to see if you have a screw on the top. Then pull on it carefully but firmly, working top and bottom How do you adjust the bottom of our slide that it will go out another 3/4 of an inch to make it even, thanks Link to comment Share on other sites More sharing options...
Chargerman Posted March 14, 2021 Share Posted March 14, 2021 Did you get the wood trim off? If so, when you open the slide all the way is the flat steel secured tight to the side wall at the bottom? Link to comment Share on other sites More sharing options...
Duanebalogh Posted March 14, 2021 Author Share Posted March 14, 2021 We haven't done thst yet going to tackle it tomorrow Link to comment Share on other sites More sharing options...
Chargerman Posted March 14, 2021 Share Posted March 14, 2021 Ok. Just curious, what makes you think the bottom of the slide isn’t all of the way out? Link to comment Share on other sites More sharing options...
Duanebalogh Posted March 15, 2021 Author Share Posted March 15, 2021 You can see on the outside where the tape mark is it doesn't like up. It doesn't line up with the ftont slide and you can see an obvious tilt Link to comment Share on other sites More sharing options...
Chargerman Posted March 15, 2021 Share Posted March 15, 2021 Got it. Let me know what you see inside with the slide extended Link to comment Share on other sites More sharing options...
Duanebalogh Posted March 15, 2021 Author Share Posted March 15, 2021 Will doWe haven't done thst yet going to tackle it tomorrow Link to comment Share on other sites More sharing options...
