Max95428 Posted March 16, 2021 Share Posted March 16, 2021 Hi the water pump in my 2002 Executive 40PBT stopped working. It appears to not be getting electricity. I checked the fuse in the bedroom closet which also connects the current to the monitor. Something weird is happening. Process: I turn on a faucet (have 3 inside) no water, then I check the fuse in the 12 volt panel in the bedroom closet , good, then I check the monitor for batteries (full), fresh water tank (full), grey water tank (1/4 full), black water tank (empty) and propane tank 3/4 full), all readings are correct . Then I turn the water pump switch on at any of the 3 faucets (I have tried it at each one) still no water. Then I check the monitor again and the readings are all at empty. I will look for a fuse in the bay with the water pump. I am suspecting the relay has malfunctioned. I will also try the suggestions in the other post about water pump problems. Thanks for helping. Max S Link to comment Share on other sites More sharing options...
Ernest Tumbleston Posted March 16, 2021 Share Posted March 16, 2021 maybe a bad ground! Carries voltage but won’t carry amps Link to comment Share on other sites More sharing options...
fiat124man Posted March 16, 2021 Share Posted March 16, 2021 There is a latching relay near the water pump. A square black box. Link to comment Share on other sites More sharing options...
Max95428 Posted March 16, 2021 Author Share Posted March 16, 2021 After I got home from work I spent some time working on my pump problem. I found the 2 inline fuses in the bay where the pump is located (a 5 and a 15 amp fuse), and the relay (Bosch 30 amp 12 volt, #091303 P1, 0332019150). I checked the fuses ( both good, then lubricated them with dielectric compound) and then I lubricated the relay pins. My pump has a splice between the front of the pump where the power comes in and the rear of the pump ( not sure if this is stock or not) but it feels like one of the wires is loose in the connector. I pushed it in hoping to get a solid connection (I will replace this connector as soon as I can get a replacement). Went into my coach to test the pump and it is now working again. Poor connections seem to have been the problem. Thanks for the help. I wouldn’t know where to begin if it wasn’t for everyone on the site that shares their knowledge nor would I have the confidence to get in there and try to fix something. Thank you Link to comment Share on other sites More sharing options...
Bob Doh Posted March 16, 2021 Share Posted March 16, 2021 just replacing mine,, on 03 Dynasty here’s a picture Link to comment Share on other sites More sharing options...
