Chuck B 31 Posted April 8 Share Posted April 8 Keep in mind that the Allison Transmission has a torque converter that comes into play when establishing driving habits. The torque converter will be locked and unlocked depending on how the transmission shifts. Chuck B Link to post Share on other sites
Jim McGarvie 11 Posted April 8 Share Posted April 8 I find this discussion quite interesting, and I am curious how much of it applies to our little 5-speed Allison 1000 with the 5.9L ISB engine. I have experimented a bit with the Econ mode, but couldn't detect a significant difference so I don't use it. On uphill grades I tend to downshift manually when I decelerate to about 1900 RPM, which jumps the RPM up to around 2500. The engine seems happier. Link to post Share on other sites
Jim McFarland 0 Posted April 8 Share Posted April 8 How interesting. I guess I don’t understand why there is such a lag time from when you step on the fuel pedal to the time the engine starts revving up and you start moving. Do all coaches with a toque converters have that issue. Sorry it appears that I have more questions than answers. Link to post Share on other sites
Ivylog 17 Posted April 8 Share Posted April 8 The Alison 3000 & 4000 6 speed transmissions only use the torque converter in 1st & 2nd gears. Starts in 1 unlocked then the torque locks, shifts to 2 unlocked and then the torque locks before shifting to 3 locked, 4 locked, 5 locked which is a overdrive & 6 locked a double overdrive. In some ways it’s a 8 speed tranny. A turbo Diesel engine is slow to get going because the turbo isn’t doing much until you get above 1400 rpms which takes awhile even with a torque converter that lets it increase rpms quicker. 1 1 Link to post Share on other sites
