Dennis-C Posted July 16, 2021 Posted July 16, 2021 Is there any kind of documentation out there for the air bag system for the Magnum Chassis. Something like a plumbing diagram for all the air lines, fittings locations, tanks, etc.? Both rear bags down on passenger rear. Tech hasn't looked yet, but doubts that both bags would be deflated at the same time by damage, so gonna look for a leaky fitting. Thanks, Dennis
Ivylog Posted July 16, 2021 Posted July 16, 2021 Arm/rod between the ride height valve and rear axle is likely broken… probably the rubber end. Big truck stops usually carry them.
veraken Posted July 17, 2021 Posted July 17, 2021 Here is a document for the Windsor & Dynasty that may help/ 1996-1999 AIR SYSTEM Dynasty and Windsor.pdf 1
CTerry Posted July 18, 2021 Posted July 18, 2021 Two air valves on back axle. My guess would the valve it self or the connector on the rod from the valve has come loose. If you can hear air leaking it is probably the valve. The attachment on the end of the valve is a rubber piece. Easy to replace if you can get to it.
