Fuel injector Calibration error
I have a Silverleaf VMspc. I get an "Error Code Thrown" as soon as I turn the ignition on (without starting).  The code is "ENG SID 1329 Injector Cylinder #13 Calibratn Error".   The engine starts and seems to run normally.  The error code seems to come in every time I hit the clear button on the VMspc screen.  There is no black smoke or any other symptoms.
The coach has been sitting for about 8 months.   We are getting ready for a long trip.  Anyone with similar experience?  Any help will be greatly appreciated.
Jim M
2007 Cayman XL
What engine make and model is in your coach?
Have you ever had an injector replaced and if so has this error shown up after the injector replacement?
On certain engines, when an injector is replaced, the new injector code must to be entered into the engine ECM.  This tells the ECM the injector calibration parameters.
Hi Frank,
The engine is a Cummins ISB 325 HP.  There has been no work done on the engine. I read about the injector calibration parameters, but I don't think that applies here since none of the injectors have been replaced.
I thought that maybe an injector had gone bad. Or possibly a corroded connector?  There does not seem to be anything obvious when looking at the top of the engine.
any idea of what symptoms to expect if the electronics in an injector has gone bad?
Jim M 2007 Cayman XL
