Kool-Magic replacement?
Testdepth
‘96 Monaco Windsor, C8.3
Decided to troubleshoot “Kool-Matic doesn’t work”, statement by PO.
Ok let’s see what it even looks like! Open the grate, 2 wires hanging there! No motor or fan or squirrel cage or anything, so I still don’t know what it is supposed to look like. I called a couple of used parts places with no luck.
Has anyone replaced it with something else? It appears that it might have been just small dc motor with a fan attached?
The Kool Matic fan has been obsolete for years.  Your only hope is to call a salvage yard.
I did find a compatible motor for mine 4 years ago from Autozone, it was a 4Seasons/Everco/A/C Heater Blower Motor PN 35551, not sure if is still available,
https://www.autozone.com/cooling-heating-and-climate-control/a-c-heater-blower-motor/p/four-seasons-new-a-c-heater-blower-motor-35551/913749_0_0
The motor that I replaced had a larger armeture but it was wore out where the brushed ran.
The fan blade itself is a simple 4 blade design that fits the shaft of the motor.
Mine is controlled by a thermostat but there is also a knob on the fan grill to change speed, it 3 speeds.
It does work well and I use it a lot.  I also have a fantastic fan in the bathroom but prefer the Koolmatic.
If you can't find parts a different type of fan may fit in the hole.
