Joe Lee Posted September 3, 2021 Share Posted September 3, 2021 My Onan 10HDKAG Series A 10k generator won’t shut down at the switch. I have replaced the fuel solenoid. It appears this solenoid needs to push forward to shut the unit down. But, the solenoid appears to only be made to pull in at start up then hold in a neutral position. It never moves forward to stop the genny. I have to do this by hand. also, I reviewed the parts manual and I am supposed to have a Rod End Clip on the arm of the solenoid. I can’t figure out what this clip would do, but that could be my missing link! Does anyone have a picture of what a properly connect fuel solenoid should look like? I have attached a picture of mine. Am I missing some parts to make it stop? Thanks!! Joe Link to comment Share on other sites More sharing options...
Ivylog Posted September 3, 2021 Share Posted September 3, 2021 (edited) Sounds like you need a spring to pull the lever closed. The solenoid should have one to push it back once the 12V is removed. A rod clip looks like the below Edited September 3, 2021 by Ivylog Link to comment Share on other sites More sharing options...
Joe Lee Posted September 3, 2021 Author Share Posted September 3, 2021 Thank you. I can’t find a spring in the Parts Catalog. I will look again! Link to comment Share on other sites More sharing options...
Ivylog Posted September 3, 2021 Share Posted September 3, 2021 Are you sure the replacement solenoid was an exact replacement? Link to comment Share on other sites More sharing options...
Joe Lee Posted September 3, 2021 Author Share Posted September 3, 2021 I believe so? It was cross referenced from the original and I have seen it on this type of genny online. But I’m open to whatever info I can get from you and this awesome group! Thanks for the help. Link to comment Share on other sites More sharing options...
dl_racing427 Posted September 4, 2021 Share Posted September 4, 2021 Did the original solenoid have a spring return built in? If the replacement does not, it should be fairly simple to rig a return spring on the arm. Just choose a spring that is strong enough to pull the stop arm to the closed position, but not so strong that the solenoid cannot pull fully in when the unit is running. Link to comment Share on other sites More sharing options...
