Mike samson Posted January 6, 2022 Share Posted January 6, 2022 Have a issue with my 43pdq start circuit works but sometimes hesitates checked ignition switch ok jumper on starter solenoid starts right up does anyone out there had this issue or can help me with electrical drawings revgroup no help navistar lnternatanal Link to comment Share on other sites More sharing options...
dandick66 Posted January 6, 2022 Share Posted January 6, 2022 Not sure what you mean by “hesitates”. If you mean intermittent, then more than likely the problem is dirty contacts in the ignition switch or the starter relay/solenoid. I’ve attached a schematic that should help you. I don’t think Monaco changed much in the starting circuitry and color codes. Dan D, 2012 Diplomat 43DFT Link to comment Share on other sites More sharing options...
