Chuck B 2004 Windsor Posted March 17, 2022 Share Posted March 17, 2022 Prestone has recalled its Shop Pro brand of RV and marine antifreeze, sold exclusively at Autozone. The recall was necessary because of a risk of methanol poisoning, according to a release from the U.S. Consumer Products Safety Commission (USPSC) The recalled antifreeze bottles have date code FT21281 printed at the bottom of the bottle and only bottles with blue fluid are affected. “Bottles labeled as Shop Pro RV & Marine Antifreeze were improperly filled with a product containing methanol. These improperly filled bottles do not have the mandatory cautionary label for products containing methanol warnings, including that the vapors are harmful and the product can be fatal or cause blindness if swallowed. Also, the directions on the bottle for properly flushing a potable water system can fail to adequately remove the methanol, presenting a risk of ingestion. Products containing methanol pose a poisoning hazard through inhalation or if ingested,” the USPSC release stated. Approximately 325 bottles were affected and customers who purchased the product should return it to Autozone for a refund. Chuck B 2004 Windsor 1 Link to comment Share on other sites More sharing options...
CorinthWest Posted March 17, 2022 Share Posted March 17, 2022 Call me cynical.....but anyone drinking anti-freeze deserves whatever happens as a result. Lawyers....... What do you call 1,000 lawyers at the bottom of the ocean? Answer: "A good start" 1 Link to comment Share on other sites More sharing options...
cbr046 Posted March 17, 2022 Share Posted March 17, 2022 1 hour ago, CorinthWest said: Call me cynical.....but anyone drinking anti-freeze deserves whatever happens as a result. Lawyers....... What do you call 1,000 lawyers at the bottom of the ocean? Answer: "A good start" This is for potable water system anti-freeze. So yes, a small amount could be ingested if the system isn't totally flushed after winterizing. I hope no one was adversely affected. - bob 1 Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted March 19, 2022 Author Share Posted March 19, 2022 On 3/17/2022 at 1:10 PM, CorinthWest said: Call me cynical.....but anyone drinking anti-freeze deserves whatever happens as a result. Lawyers....... What do you call 1,000 lawyers at the bottom of the ocean? Answer: "A good start" Cynical. Chuck B 2004 Windsor 1 Link to comment Share on other sites More sharing options...
