Jcwag42 Posted March 20 Share Posted March 20 I need some ideas… All of a sudden my. Control panel generator start button will not work. I’ve checked for fuses and cannot find any. Anyone out there with a solve? Gary 2001 Monaco Dynasty Link to comment Share on other sites More sharing options...
jacwjames Posted March 20 Share Posted March 20 You probably have another generator start button in the bedroom, check it. First thing I'd check is the wiring harness on the passenger side of the generator. sometimes this will get condensation in it. Pull it apart, blow it out and put some dielectric grease on it. Link to comment Share on other sites More sharing options...
Jcwag42 Posted March 21 Author Share Posted March 21 I tried that it but it didn’t solve the problem. The weird part is it shuts off from inside but won’t start from inside.🤔 Link to comment Share on other sites More sharing options...
jacwjames Posted March 21 Share Posted March 21 Does the generator start from the inverter panel?? If it is stopping using the inside button it may be just the wire that does the start function. Not too long ago an individual had a problem where his EMS was not recognizing the generator was running. He ultimately found one wire in the harness had come loose from the pin. Do you have a wiring diagram for your coach?? Attached is a screen shot of the wiring for my generator start, yours should be close. I believe that to stop the generator it actually just closes a connection to ground, the Brown wire on the diagram. The Red wire is for starting. I'd check to see if you are getting power on that at the harness when you press a start button inside. Note>>> when you open the file it will be blurry, hit the CTRL5 buttons at the same time and it will clear right up. Generator start switch wiring.pdf Link to comment Share on other sites More sharing options...
