Rick Rutel Posted March 26, 2022 Share Posted March 26, 2022 2008 Camelot 42pdq. I know it's in the coach somewhere, but the coaxial cable for the original CB antennae on the roof is MIA inside. I've pulled the side panel, top dash panel, removed the front drawers, crawled around under the dash and no joy. According to a tech that buiult the Monaco coaches at the factory, the cable should be inside the lower panel under the air brake pull. I give. Help? Link to comment Share on other sites More sharing options...
Summer Fun Posted March 26, 2022 Share Posted March 26, 2022 My 2009 Diplomat was hard to find. It was almost dead center ( a little more towards the e drivers side ) and against the farthest forward part under the dash. It was all curled up and hd about five wire ties holding it in place. Maybe 14” right of the gas pedal and against the front wall. Good luck. Only took about two hours to find. Glad my daughter is skinny. Link to comment Share on other sites More sharing options...
Rick Rutel Posted March 26, 2022 Author Share Posted March 26, 2022 Thanks. Skinny, I am not. Hopefully I can find it without having to call Fire Rescue to pull me out from under the dash. Link to comment Share on other sites More sharing options...
Summer Fun Posted March 26, 2022 Share Posted March 26, 2022 Good luck on that. I am not skinny either. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted March 26, 2022 Share Posted March 26, 2022 I found mine behind the radio. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
Happycarz Posted March 28, 2022 Share Posted March 28, 2022 The CB cable for your 08 Camelot is mixed in with the four miles of wires in the left console (under the shifter pad.) Just keep moving the wires until you see it. Link to comment Share on other sites More sharing options...
Bjohnsonmn Posted April 12, 2022 Share Posted April 12, 2022 Mine ran right behind the radio (where my CB box was mounted). Then, it runs along the dash and up the right side A pillar to the space behind the cabinets and back across to the left side where it would go through the roof, but it is disconnected and laying there with the hole patched. Link to comment Share on other sites More sharing options...
Rick Rutel Posted April 13, 2022 Author Share Posted April 13, 2022 I looked where people suggested, as far as I could physically fit. Still, no luck. Didn’t think about pulling the panel off near the windshield. That’ll be today’s search. Link to comment Share on other sites More sharing options...
Hubert wells Posted July 10, 2022 Share Posted July 10, 2022 I finally found my CB cable in my 08 diplomat , I had to remove the steering column cover and there it was ! Link to comment Share on other sites More sharing options...
