Posted
How do the vertical slide wood trim pieces come off on an 09 Sig. I know the horizontal piece hook and hangs over a piece of aluminum and is held then by velcro pieces. I can't figure out the vertical ends and don't want to break one. It seems as though maybe velcro also but I thought I was going to pull a slide in trying to remove a piece....lol I am referring to the wood trim.
Posted
The vertical trim on my 2007 Dynasty is held in place with velcro and some construction adhesive. The pieces were not exactly easy to remove using a small pry bar.
Bill B 07 Dynasty
Posted
Actually I figured out that mine has 3 screws from the back in between the two rubber seals....You can't wee them unless you close the slide and then seperate the seals on the back of the aluminum.....What a PITA....lol, but now I know....I have velcro also.
