MHRookie Posted April 5, 2022 Share Posted April 5, 2022 All, Wondering about upgrading our MSW trace 2012 to a new Xantrex PSW 2012. I’m being told it’s basically a plug & play swap and I can still use my RG7 control. Anyone had this done? Thanks, Kurt 2003 Monaco Dynasty 42’ Link to comment Share on other sites More sharing options...
1nolaguy Posted April 5, 2022 Share Posted April 5, 2022 I am not familiar with the MSW Trace. Last year I had planned to replace my old Xantrex FREEDOM 2500 (MSW) with a new Xantrex FREEDOM 3000 (PSW). Unfortunately Xantrex were out of stock about nation wide and so I ended up with an AIMS. Anyway, when initially preparing to replace the Xantrex with a Xantrex I learned that a new remote is needed but they make a device that will allow you to use the same RJ11 (phone cord) to connect the new remote to the inverter. The "converter" cables basically change the RJ11 to RJ45 (data patch cord) connector required by the new remote and new inverter. Hope this helps. Link to comment Share on other sites More sharing options...
MHRookie Posted April 6, 2022 Author Share Posted April 6, 2022 Thanks for that share! Link to comment Share on other sites More sharing options...
1nolaguy Posted April 6, 2022 Share Posted April 6, 2022 I should also note that for the Aims I had to run new CAT5/6 line from the inverter Bay to the place inside where the remote is located. Take wiring needs into account when you order your new I/C so you have everything you need handy when planning the install. In my case the inverter must be working for most of the 120v outlets to work on pass thru. If you are full time and have such a configuration it can create added problems if you do not have everything you need when you start the install. Link to comment Share on other sites More sharing options...
