Squints2c Posted May 14, 2022 Share Posted May 14, 2022 When my 2006 Cayman was towed they folded the mirrors in toward the windshield. Ive loosened the bolts but cant get them fold back to the normal position. Is there a trick to it? I have tried the adjustment switch, and the glass moves but that is all that it does.Unfold Link to comment Share on other sites More sharing options...
Gary M Posted May 14, 2022 Share Posted May 14, 2022 Tap up on the bolt to break loose the taper on the arm. Link to comment Share on other sites More sharing options...
Squints2c Posted May 14, 2022 Author Share Posted May 14, 2022 5 minutes ago, Gary M said: Tap up on the bolt to break loose the taper on the arm. Thanks, Ill give it a try. Link to comment Share on other sites More sharing options...
Squints2c Posted May 16, 2022 Author Share Posted May 16, 2022 Took a few hits but worked. Thanks 1 Link to comment Share on other sites More sharing options...
