dandick66 Posted May 16, 2022 Share Posted May 16, 2022 My 2012 Diplomat generator uses the house batteries for starting. This is a poor design as the generator struggles to start from them. I’ve seen posts where users add a separate starting battery and isolator up front at the generator. I was looking into this when I thought I’d look at the possibility of moving the starting cable from the house batteries to the chassis batteries. I found where the generator cable is connected to the house battery bus and found an empty connection on the chassis bus. I can make a jumper/extension for the cable and get it moved, but I discovered something with the power that I don’t understand. When I turn the house or chassis disconnect switches off, I still read voltage on both buses. However, if I turn both disconnects off, I only get voltage on the respective buses when I turn the chassis or house switch on. If I turn both switches on, after about 30 seconds I hear the Big Boy energize and then I get the same symptoms - if I turn either switch off, there is still voltage on the buses. I thought the Big about was an isolator and would only pass power when charging, or when you push the battery boost switch. Link to comment Share on other sites More sharing options...
