gjh2916 Posted May 20, 2022 Share Posted May 20, 2022 On my 2001 Monaco Dynasty is there a relay or something that provides power to the ignition switch? When I turn the ignition key on sometimes it starts ok and other times nothing happens. If I just turn on ignition and don't try to start after a few seconds all my dash instruments start turning off and on. Something is interrupting power to the ignition switch. I have replaced the starter solenoids and checked the rear/front run switch. The ignition switch was replaced about 2 years ago. Link to comment Share on other sites More sharing options...
gjh2916 Posted May 21, 2022 Author Share Posted May 21, 2022 Problem solved, replaced the continuous run chassis solenoid in the rear run plate. Link to comment Share on other sites More sharing options...
