KevinH Posted July 5, 2022 Share Posted July 5, 2022 I have a 2006 Beaver Patriots thunder with three point Power Gear hydraulic jacks. My reservoir tank is leaking. I called Lippert And they said they don’t make that tank anymore . But they do make a replacement it’s a square tank not round like mine. And they weren’t 100% sure it would work. I haven’t been to the RV yet to see if the square tank will fit. I was just wondering if anybody else has had this type of problem. Thanks Kevin Link to comment Share on other sites More sharing options...
Guest Dive Dive Posted July 5, 2022 Share Posted July 5, 2022 Mine was cracked at the neck. I took it off and had it brazed by a welder for $30 and it works great now. Link to comment Share on other sites More sharing options...
KevinH Posted July 6, 2022 Author Share Posted July 6, 2022 It looks pretty straightforward removing it there’s a drain plug on the bottom ,four bolts and a 12 V sensor is it that simple? Link to comment Share on other sites More sharing options...
Guest Dive Dive Posted July 6, 2022 Share Posted July 6, 2022 Yes it’s very simple. Remove the drain plug and drain the oil. Disconnect the electrical connection. Then remove 4 bolts around the neck. On my Cayman I can open the door for the transmission cooler and swing that little radiator out of the way to get to it easily. Im not sure if it is as easy on other models. Link to comment Share on other sites More sharing options...
vanwill52 Posted July 6, 2022 Share Posted July 6, 2022 I think that by now, almost everyone has realized what "RV Quality" means, when describing a product. It often means, "the most poorly conceived, poorly engineered, lowest quality". This forum and its innovative "out of the box" thinkers keep our old beasts rolling. I just tripped over 200K on my 2000 Dynasty, and I would not hesitate to take it to CA (stopping just short of the state line, so I don't get "infected" with weird ideas). Of course, I've repaired/replaced virtually every system PROACTIVELY with updated, quality components when possible. My WH is next...22 years old and doing great, but a ticking time bomb. Thanks for all the help I've gotten from so many of you! 1 Link to comment Share on other sites More sharing options...
