sg47619 Posted July 12, 2022 Share Posted July 12, 2022 Does anyone have a idea where the light in the cord real compartment gets its power from. It’s on a 2001 Monaco Dynasty Jack 38. Link to comment Share on other sites More sharing options...
Fasthobie16 Posted July 12, 2022 Share Posted July 12, 2022 The light in my water fill/ dump compartment has a switch on the fixture itself. 2000 Dynasty 40’ Link to comment Share on other sites More sharing options...
BradBak Posted July 13, 2022 Share Posted July 13, 2022 Mine is supplied from the house batteries and has a switch on the door to turn it off and on Link to comment Share on other sites More sharing options...
sg47619 Posted July 13, 2022 Author Share Posted July 13, 2022 2 minutes ago, BradBak said: Mine is supplied from the house batteries and has a switch on the door to turn it off and on Mine has the switch there but it has no power, question I’ll start chasing wires Thanks Link to comment Share on other sites More sharing options...
BradBak Posted July 13, 2022 Share Posted July 13, 2022 Mine had power but the contacts were rusted all I did is clean the the contacts and been working since it will stick every now and again so I jus snap it and the spring inside cleans the contact Link to comment Share on other sites More sharing options...
Roger 2006 HR Endeavor PDQ Posted July 13, 2022 Share Posted July 13, 2022 On our 2006 Endeavor, the light fixture had the positive side hard wired to the light fixture and the negative (ground) wire completed the circuit through the plunger switch on the door. Roger Smalley 2006 Endeavor PDQ Link to comment Share on other sites More sharing options...
TXcamping Posted July 13, 2022 Share Posted July 13, 2022 On our coach, you have to turn on the "bay lights" switch by the front door, then the small switch in the bay gets power. Link to comment Share on other sites More sharing options...
BradBak Posted July 13, 2022 Share Posted July 13, 2022 No, not on mine 2006 Monaco 33sfs. It has power all the time .it is the only compartment that has power with out the switch by the entrance door but my polarity was wrong as stated and I had the polarity when I installer eld lights in all compartments. Link to comment Share on other sites More sharing options...
sg47619 Posted July 13, 2022 Author Share Posted July 13, 2022 52 minutes ago, TXcamping said: On our coach, you have to turn on the "bay lights" switch by the front door, then the small switch in the bay gets power. Ok. I’ll try that thinks Link to comment Share on other sites More sharing options...
