Kenneth Posted August 8, 2022 Share Posted August 8, 2022 Aladdin was reset on monitor option rest, by grandkids, now my front monitor says no signal camera 3 and Aladdin is not coming up, worked great before, how can I make it all work again Link to comment Share on other sites More sharing options...
Frank McElroy Posted August 8, 2022 Share Posted August 8, 2022 2 hours ago, Kenneth said: Aladdin was reset on monitor option rest, by grandkids, now my front monitor says no signal camera 3 and Aladdin is not coming up, worked great before, how can I make it all work again If your Aladdin display is like mine, it has two video inputs. On the front of the display screen, try selecting the camera video input by pushing in the input camera button. It sounds like your grandkids are like mine - they love to push buttons and throw things down the macerator toilet that they shouldn't. Link to comment Share on other sites More sharing options...
Kenneth Posted August 8, 2022 Author Share Posted August 8, 2022 Mine will not respond nor on the joy stick or the monitor, but screen says no signal camera 3, I can't do anything and it will not show anything else Link to comment Share on other sites More sharing options...
Frank McElroy Posted August 9, 2022 Share Posted August 9, 2022 Have you already tried using the Aladdin reset switch? Mine is located on the passenger side in the cabinet above the door. Link to comment Share on other sites More sharing options...
Kenneth Posted August 10, 2022 Author Share Posted August 10, 2022 On 8/8/2022 at 8:07 PM, Frank McElroy said: Have you already tried using the Aladdin reset switch? Mine is located on the passenger side in the cabinet above the door. Yes I have, Link to comment Share on other sites More sharing options...
Georgia Mike Posted August 10, 2022 Share Posted August 10, 2022 We don’t know what year/model you have but on my 06 I have the Sony monitor and on the face there is an input button that says A,B,C the kids might have changed it. Link to comment Share on other sites More sharing options...
Frank McElroy Posted August 10, 2022 Share Posted August 10, 2022 Your coach should have a rear display and joy stick. If so does it show the same error message? The message saying no signal camera 3 sure sounds like the display should be set to camera 1 to see the Aladdin display. Link to comment Share on other sites More sharing options...
Kenneth Posted August 11, 2022 Author Share Posted August 11, 2022 The rear unit works as is it should with no problems My coach is a 2006 monaco dynasty Link to comment Share on other sites More sharing options...
Frank McElroy Posted August 11, 2022 Share Posted August 11, 2022 12 minutes ago, Kenneth said: The rear unit works as is it should with no problems My coach is a 2006 monaco dynasty OK good. This tells me that the main Aladdin computer module and the Aladdin components are all working. The problem is with your dash display. What model dash display are you using on your dash? Are you able to set the display on the screen itself to camera 1? Link to comment Share on other sites More sharing options...
Kenneth Posted August 16, 2022 Author Share Posted August 16, 2022 On 8/10/2022 at 8:47 PM, Frank McElroy said: OK good. This tells me that the main Aladdin computer module and the Aladdin components are all working. The problem is with your dash display. What model dash display are you using on your dash? Are you able to set the display on the screen itself to camera 1? i can not change my monitor at all it is frozen on camera 3 no signal i replaced the monitor 2 months ago with a new voyager. it worked perfect then Link to comment Share on other sites More sharing options...
