Katahdin Girl Posted March 15, 2023 Share Posted March 15, 2023 We own one of the few Majestic V’s manufactured as Monaco was going out of business. We did not receive a manual for the coach and instead were given a 2009 Dynasty manual. On our last trip the slide within a slide did not fully extend. We had a mobile repair service and he manually got it out the last several inches but could not get it to retract. We do not have a wiring diagram for the coach and are hoping we can get help figuring out how to get it fixed and get back on the road. Fortunately we are parked on our lot at Bella Terra for the winter. Link to comment Share on other sites More sharing options...
Frank McElroy Posted March 15, 2023 Share Posted March 15, 2023 Yes, Monaco made very few 5 slide design coaches like yours. On your coach, the front driver's side slide is a slide out within a slide out. Both are electric. A few years back I helped solve a similar problem on a Majestic V. The issue was with a bad reed switch on the slide out itself. To operate either the inner or outer slide, the other one must be fully extended or fully retracted. The control logic is programmed into the House Intellitec Multiplex system. Just one of the 4 reed switches going bad or out of alignment can cause your problem. Attached is a link to a set of wiring schematics. If you click on the title, you'll get an option to download the complete set in one PDF file. Not included in this set are the two drawings you need for the slide in a slide controls. But, I am attaching pictures of those drawings I received when helping another member offline a few years back. I hope this information helps to solve your problem. pg_3010001343oc.pdf 1 Link to comment Share on other sites More sharing options...
Solution Katahdin Girl Posted March 16, 2023 Author Solution Share Posted March 16, 2023 Thanks for the information. We are back in New Jersey (Hackettstown) and will be heading back to our coach in Foley Alabama soon. Meanwhile I will get this information to our tech there. Link to comment Share on other sites More sharing options...
Katahdin Girl Posted March 19, 2023 Author Share Posted March 19, 2023 Frank, would you be able to email the diagrams directly to our tech who will be working on the slide? I printed them out but the detail is hard to read. We won’t be back to the coach until Monday the 27th. His email is mustardseedgarage@yahoo.com. Thanks so much! Link to comment Share on other sites More sharing options...
Frank McElroy Posted March 19, 2023 Share Posted March 19, 2023 Two days ago I uploaded a new higher resolution complete file of schematics. The link is the same as my previous post. Anything I have won't be higher resolution. Link to comment Share on other sites More sharing options...
Katahdin Girl Posted April 4, 2023 Author Share Posted April 4, 2023 Any idea where the reed switches are located? Tech is here now looking for them Link to comment Share on other sites More sharing options...
