Richard Tree Posted April 24, 2023 Share Posted April 24, 2023 Trying to trace down an intermittent connection for the water temp gauge (Beede) on my Neptune. The Monaco chassis schematics have in-harness connectors designated by SCT xx (number). What does the term SCT stand for? THX Link to comment Share on other sites More sharing options...
Gary Cole Posted April 25, 2023 Share Posted April 25, 2023 In the electrical industry SCT describes a straight blade connector in a NEMA classification as opposed to twist lock or pin and sleeve for example. I really don't know if it means the same in automotive terminology. Link to comment Share on other sites More sharing options...
Richard Tree Posted April 26, 2023 Author Share Posted April 26, 2023 Found it.... The Monaco wiring diagams use in multiple locations, a "single conductor terminal" (SCT) ie a crimp-on wire ring terminal sized to take multiple or single wires. Examples are the multiple grounds for the ECM to the chassis battery using a single ring terminal, or another such as the single ring terminal on the back of a gauge. The numbers (tagged in the harness) help the installer place the right number terminal of the respective bolt or screw position. Link to comment Share on other sites More sharing options...
