Garry Donohue Posted July 6, 2023 Share Posted July 6, 2023 My dash A/C works but the belt is way too loose. I can see the bolts but would like a step by step info on how and which bolts to loosen and then tighten? Link to comment Share on other sites More sharing options...
Solution Happycarz Posted July 7, 2023 Solution Share Posted July 7, 2023 If your belt arrangement is like mine, this should help. Link to comment Share on other sites More sharing options...
Garry Donohue Posted July 7, 2023 Author Share Posted July 7, 2023 Yes that looks like mine. That makes it so much easier with photos. Thank you so much for your time! Link to comment Share on other sites More sharing options...
Happycarz Posted July 8, 2023 Share Posted July 8, 2023 Glad to help. A couple more pictures for you. I don’t recall if the bolt in my second picture is threaded into the bracket, or is a long bolt with nut on it. And, I stated that there was two bolts on the pivot, but it is just one long one. Link to comment Share on other sites More sharing options...
Garry Donohue Posted July 8, 2023 Author Share Posted July 8, 2023 It was that threaded adjustment screw that had me confused. Thanks Harry. Link to comment Share on other sites More sharing options...
Guest jerrygrosman Posted July 9, 2023 Share Posted July 9, 2023 Maybe it is not loose. It was made that loose so the bearings do not have too much pressure on them. Maybe the belt is getting old and needs replacing. But the big question is why not just stop in at a dealer and let them look at it and adjust it. Maybe a hour labor and a peace of mind. Link to comment Share on other sites More sharing options...
Garry Donohue Posted July 10, 2023 Author Share Posted July 10, 2023 Thanks Jerry but it is so loose, it’s about to jump off. Judging by past inspections. As for a dealer, I’m in New Jersey and I only have a Camping World near me, I resist going there. It look’s pretty straight forward to tighten myself thanks to Harry and Frank, Link to comment Share on other sites More sharing options...
Garry Donohue Posted July 12, 2023 Author Share Posted July 12, 2023 Harry; Do you know what type of wrench is for the A/C bolts ? Standard or metric? I can’t seem to locate the correct wrench. Link to comment Share on other sites More sharing options...
