Cajunboy1959 Posted July 24, 2023 Share Posted July 24, 2023 Good morning Monacoers, I'm new to this. I've had my Safari Cheetah 38PDQ for 3 months. I have 4 electric power glide slides. The front two and the drivers side read go in and out when I use the switches at control panel. My rear passenger slide works both manually and when I apply 12volts. On the in out switches there are 3 positions middle supplies 12 volts and the other two pins are for in and out. My issue is on my rear passenger switch there seams to be a short. With a continuity meter both wires show short to ground. I have found the relay board and all relays but one tested good. I put a new one in. Same thing short on two wires. I have the 12volts on center pin but when I operate in or out even with motor unplugged it still blows the fuse on the relay board. Can any one tell me if there is another board besides the ones in the pictures. I'm trying to run 2 new wires for the switch but I cannot figure out where these two wires go to. Does the relay board in the pictures control all 4 slides or just the three that are working? Any help would be appreciated. Thanks Reply to this topic... Share Following 6 Go to topic listing Next unread topic Privacy Policy Contact Us Cookies Copyright © 2022 Monacoers, Inc. All Rights Reserved.Powered by Invision Community Link to comment Share on other sites More sharing options...
