Robert92867 Posted September 12 Share Posted September 12 Not all radiators can withstand a Sunjoe 1700 psi pressure washer. This particular radiator is a 2015 CGI aluminum 3-core model for a rear radiator Monaco. The 4-core models are more $ and harder to clean. DCIM_125APPLE_IMG_5615.MOV Link to comment Share on other sites More sharing options...
1nolaguy Posted September 12 Share Posted September 12 Pressure washers should never be used on finned radiators, especially those with aluminum fins. Even a water stream from a garden hose nozzle can damage aluminum fins. I was advised that the best way to clean the radiators( and also your A/C coils) is with lots of running water and from the side that air usually flows through. For radiators that is from the out side toward the engine. I do this every time I wash the rig. If your coils are really dirty water them down and then spray on a mix of water with dawn and distilled vinegar. let it soak for 10 minutes then rinse and repeat at needed. Alternately you can use a commercial coil cleaner which come from big box stores in a spray foam or from an HVAC supply house, usually in a concentrate that is to be diluted with water. Spray on, let soak about 10 minutes, rinse and repeat as needed. I find the best way, once thoroughly cleaned, is to rinse with plenty of water regularly and then once or twice a year I do the Dawn/vinegar thing as noted above. Also, if you have fins that are pushed over use a fin comb or stiff plastic bristle brush to "comb" the fins back straight. It is amazing how much heat exchange efficiency can be lost by a coil when fins are bent over, even partially, and restrict air flow. Link to comment Share on other sites More sharing options...
