96 EVO Posted November 23, 2023 Share Posted November 23, 2023 1 hour ago, Tom Cherry said: Steve, Be aware. You must use the Shifter Key pad to check the Allison. Doubt you have a dipstick. Must drive it to get it hot...as in around 195 dF. Then park and LEVEL. Then follow instructions for used the Electronic Level Keypad. Should have an Allison manual in your "Files" or google it. You match the shifter style in the Allison manual and then do that. Then other engine fluids like Oil and Coolant... Why wouldn't a transmission problem light his 'Check Trans' lamp? Link to comment Share on other sites More sharing options...
