Newcsn Posted December 17, 2023 Share Posted December 17, 2023 I recently replaced the impeller on our Shurflo 3200 macerator pump. After running it for a bit, it appears the shaft seal is leaking & needs to be replaced. The only thing I've been able to find online is the complete impeller housing assembly - for about $100. https://defender.com/en_us/shurflo-macerator-pump-impeller-housing-kit-94-570-00 Wondering if anyone has encountered this before & found a seal part number. I suspect this little seal would be a max on $10-15 - if you can find one. If we can't find just the seal, it doesn't seem to make much sense to pay $100 for the housing when you can buy a new pump for $185! Link to comment Share on other sites More sharing options...
Dennis H Posted December 18, 2023 Share Posted December 18, 2023 The kit I use is for a Jabsco pump but they might be identical. A call to Jabsco will tell you. The kit Model is 18598-1000. IIRC I purchased it from Amazon....Dennis Link to comment Share on other sites More sharing options...
Paul J A Posted December 18, 2023 Share Posted December 18, 2023 The boating world uses them extensively. I would try West Marine. Link to comment Share on other sites More sharing options...
