Doug and Nicki Posted February 13 Share Posted February 13 I have a 2008 Dynasty and this backup light lens is discolored. The opposite side is white. Anyone know how these are removed? Looks like they are placed from the inside with adhesive. Link to comment Share on other sites More sharing options...
LakeBob Posted February 13 Share Posted February 13 They just pop out. Disconnect the plug and push out. There are probably stuck in pretty well. Link to comment Share on other sites More sharing options...
Doug and Nicki Posted February 14 Author Share Posted February 14 Push them inward or outward? Link to comment Share on other sites More sharing options...
windsorbill06 Posted February 14 Share Posted February 14 31 minutes ago, Doug and Nicki said: Push them inward or outward? The black rubber that holds the light in, was quite pliable when new. It could be as hard as a rock and/or very brittle now and need to be cut enough to release the light from it's grip. I'd be inclined to work from inside as to minimize chances of scratching the outside of coach. Link to comment Share on other sites More sharing options...
Doug and Nicki Posted February 14 Author Share Posted February 14 Thanks. The black rubber on mine is still pliable but it looks like the best bet is to use a putty knife around the light fixture on the inside to release it. Not sure what was used to make it stick. Looks like some sort of black tar like stuff. Link to comment Share on other sites More sharing options...
LakeBob Posted February 14 Share Posted February 14 Yes, push outward. A little penetrating oil may help. Mine were fairly easy to break loose, however the rubber was compressed tightly into the opening. I did not have any sealing material applied around the inside of the light. The lights had been replaced once before so I’m guessing that made mine fairly easy to remove Link to comment Share on other sites More sharing options...
