Lionel blain Posted February 19 Share Posted February 19 my keyless entry worked great untill i shut down the 12 volt power to paint the battery tray, when i turned the power back on the pad lights up, beeps but wont lock or unlock the door or the basement. i looked for fuses but found none that were blown. Any ideas?? Link to comment Share on other sites More sharing options...
vito.a Posted February 20 Share Posted February 20 Your keypad has probably lost its programming. Try reprogramming it. Link to comment Share on other sites More sharing options...
vito.a Posted February 20 Share Posted February 20 Attached is the Essex user guide. If you need to replace the keyboard, the part number is: Essex KE-1701BHC (“C” means Monaco connector) They are available from A1 Electric in Torrance CA. Phone: (310) 328-8500 Essex Keyless KE1701 UserGuide.pdf Link to comment Share on other sites More sharing options...
Lionel blain Posted February 20 Author Share Posted February 20 thanks guys< i reprogramed the keypad before i started this thread, but i tried it again and had to do it several time but it finally worked, will have to remember this for future. thanks again Lionel Link to comment Share on other sites More sharing options...
