JDPenn Posted April 27 Share Posted April 27 Looking for discussion on Lapalma gasser lithium upgrade, mounting options, disconnecting battery boost, WFCO lithium replacement, etc. I would like to use existing battery trays under the steps, but sizing options appear limited without modifying the trays. I've already installed a PD lithium WFCO replacement in another trailer, so that should be straightforward. Need more info on separating house and chassis batteries, bird, bim, whatever. Thanks! Link to comment Share on other sites More sharing options...
timaz996 Posted April 27 Share Posted April 27 If sizing is an issue look up Lossigy 200 ah batteries. I have four for the last two years and love them full timing. Link to comment Share on other sites More sharing options...
CAT Stephen Posted April 28 Share Posted April 28 Hello JD, I can help you spec out the right components for your needs if you can answer the following questions: - What is the rated maximum output of your current coach engine alternator in amps? - What is the nominal voltage of your current coach engine alternator? - What is the nominal voltage of your current house battery system? - What is the rated maximum output of your current generator in kilowatts? - What is the rated maximum running output of your current inverter? - What is the rated maximum surge output of your current inverter? - Do you have soft-starters installed for your rooftop air conditioners - How many rooftop air conditioners are installed on your coach? - What is the house Amp-Hour battery capacity that are you seeking? - What are the dimensions for the area that will hold your future LiPO4 house batteries (Length X Width X Height)? Link to comment Share on other sites More sharing options...
JDPenn Posted April 28 Author Share Posted April 28 -What is the rated maximum output of your current coach engine alternator in amps? - What is the nominal voltage of your current coach engine alternator? Standard 12 volt 130 amp alternator. But, I plan on separating house and chassis batteries, so alternator will only be charging chassis battery. I have a dcdc charger that I may add at some point to charge the under the steps lithium while traveling. I already have this setup in my truck and travel trailer. My travel trailer has dcdc from truck, 800 watts solar, 576 amps lithium, 2 solar converters, and 4000 watt inverter. - What is the nominal voltage of your current house battery system? 12 volt. I plan on replacing the 2 house batteries under the steps with 1 or 2 lithium batteries and upgrading the GFCI converter to a PD lithium replacement. - What is the rated maximum output of your current generator in kilowatts? It is a 5000 on an gen - What is the rated maximum running output of your current inverter? - What is the rated maximum surge output of your current inverter? This coach does not have an inverter. - Do you have soft-starters installed for your rooftop air conditioners No, but I would like to add them. - How many rooftop air conditioners are installed on your coach? Two - What is the house Amp-Hour battery capacity that are you seeking? Appx 800 - What are the dimensions for the area that will hold your future LiPO4 house batteries (Length X Width X Height)? I haven't determined which bay I will be using. What I would like to do is add the lithium under the steps and the upgraded PD converter and use this only for DC loads. Then add a separate lithium system in a bay for an AC feed. Maybe an all in one unit feeding the AC side of the coach. Will also add solar to support the all in one system. This will be an additional power source in addition to gen and shore power. Under the steps lithium will be charged with gen, dcdc, or possibly separate solar setup. Just looking for folks who have already installed a system and the options they chose. There are a lot of possibilities. Thanks. Correction - GFCI converter should be WFCO Link to comment Share on other sites More sharing options...
CAT Stephen Posted April 29 Share Posted April 29 (edited) JD, One more question since you do not currently have an inverter: - Do you plan on adding an inverter in the future? If you do: - What is the rated maximum running output of your future inverter? - What is the rated maximum surge output of your future inverter? Edited April 29 by CAT Stephen Link to comment Share on other sites More sharing options...
JDPenn Posted April 29 Author Share Posted April 29 All to be determined. What do you recommend? Link to comment Share on other sites More sharing options...
CAT Stephen Posted April 30 Share Posted April 30 21 hours ago, JDPenn said: All to be determined. What do you recommend? Thanks JD, Inverter: I would strongly recommend the Victron 12V MultiPlus-II 3kVA 2x120V Inverter/Charger for your application: https://www.currentconnected.com/product/victron-12v-multiplus2-3000va-2x120/ 10 year warranty included through this vendor https://www.victronenergy.com/upload/documents/Datasheet-MultiPlus-II-3kVA-2x120V-EN-.pdf This inverter will handle one a 2400W continuous power and 5500W surge power: Keep in mind that this inverter will not start an AC rooftop unit without a soft starter due to the massive air conditioner start up surge demand If you locate your house battery bank more than a few feet away, be prepared to make a major investment in wiring (i.e. $700+) due to the high power draw which drives very large wire gage. The mission, if possible, is to keep your inverter in close proximity to your house battery bank. DC to DC charger: You may use any brand / model. But, if you desire accurate energy measurements via shunts, the the DC to DC charger must be an isolated version. Here is the isolated DC to DC charger that I recommend: https://www.currentconnected.com/product/victron-orion-smart-tr-dc-dc-charger/ A DC to DC charger is only needed if you desire to charge your house battery band from your engine alternator You may purchase multiple Victron Energy DC to DC chargers then wire in parallel for increasing the DC to DC charging capacity, but verify that you will not exceed your alternators rated output to avoid a very expensive alternator replacement Shunts: You will need a shunt wired on the 12V negative polarity for each electrical subsystem subsystem (i.e. inverter, DC to DC charger, solar controller, ect.) There are two options that I recommend. Select the option that aligns best with your future use case: Option #1 - Fully Integrated Power Distribution: If you have limited physical space for your power distribution system and you are willing to pay a premium, the benefit will be a very clean and visually appealing install that will substantially reduce install labor, reduce required installation space, and provide integral wire management and shunt modularity: https://www.currentconnected.com/product/victron-lynx-power-in-distribution-system/ https://www.currentconnected.com/product/victron-lynx-shunt-distribution-system/ Buy one (1) for each needed shunt Option #2 - Traditional Power Distribution: If you are seeking the lowest cost install and are comfortable with specifying and installing your own buss bars for 12V high capacity power distribution, and have the physical space to accommodate a traditional power distribution system: https://www.bluesea.com/products/category/18/BusBars You will need to perform the capacity calculations for each buss bar according to your house wiring requirements https://www.currentconnected.com/product/victron-smartshunt/ Buy one (1) for each needed shunt House Battery Bank: For anything Lithium, keep in mind that there are numerous battery manufacturers that do not honor their warranties. Thus, stay with the following brands: AO Lithium https://aolithium.com/collections/all-products/products/aolithium-12v-200ah-lifepo4-lithium-battery Highest peak discharge rate in the industry (200A per battery, 800A for four (4) wired in parallel) 8 year warranty Excellent build quality Chins https://www.amazon.com/12V-400Ah-Lithium-4000-15000-Lifetime/dp/B09BR4C358/ref=sr_1_32?crid=1AQJ14X6L873B&dib=eyJ2IjoiMSJ9.0JQjmOc53qVxPyZteCN0ggDK2NgIExE1CN_wslcX2EylO-bqduJ5LFb7_occQUCAE-m4OhC9zUfXcCpbkIjLD6qZ9s55ZlsBqGh3glqDd9hF-SCKbz9i3AB7_Ez9GT0bfy4kAWIcNnvWYEO0BA8ZFW5fOalHbTjqvV6mf2Hwn_PBDdGdAVHBaqHjRDmnWH98lPaE32yaoI9qp0oXsdVt0IRke85b3nHVm5p2KU3u0eJOE9-3rhF1KI0pVN7zYZJLM4qPTipjv9GWcPMYhKHOssaL9yTff487YsH-9JtAiy8.q2BhFXo1SnFtx-jZmibepyy_qj3EL6-CfurcxDwb3y4&dib_tag=se&keywords=chins%2B12v&qid=1714486769&sprefix=chins%2B12v%2Caps%2C150&sr=8-32&th=1 One of the industry leaders for cost per watt Excellent build quality Best in industry 10 year warranty SOK https://www.currentconnected.com/product/sok-sk12v206-lifepo4-battery/ Excellent build quality Battleborne https://battlebornbatteries.com/ Excellent build quality Poor value in terms of cost per watt System Controller: This unit the the communications center for the Victron Energy platform: https://www.currentconnected.com/product/victron-cerbo-gx-kit/ What I did not Include: There are many miscellaneous proprietary and standard cables needed for the complete installation. I can help you with those details after you complete your selection of components above and after you finalize the locations for your inverter, house battery bank, DC to DC charger, and power distribution. We will need to further understand your use case to determine if LiPO4 battery heaters will be required in cold weather 1 Link to comment Share on other sites More sharing options...
JDPenn Posted May 3 Author Share Posted May 3 Thank you for your very thorough recommendations. Victron equipment is highly rated, although expensive. There are many alternatives now such as EG4. I like some of the newer all in one units now coming out. I already have some equipment on my travel trailer that I can reuse possibly, a Renogy DC DC charger, a 4000 Giandel inverter, lots of various gauge welding wire, a Victron Smart BMV712 which I love the Bluetooth monitoring, etc. I won't be reusing the 4 Valence lithium batteries but will upgrade to newer batteries, or the 4 Rich 190 solar panels, or the 2 EP Ever solar controllers. I plan on phasing in the installs a piece at a time. 1. Get a new AGM chassis battery 2. Get 1 or 2 new heated, or low temp cutoff lithiums to replace the 2 house batteries under the steps. 3. Figure out how to disconnect the chassis, house boost function. 4. Get a PD lithium replacement for the WFCO converter charger. 5. Add the dcdc charger and 712 shunt. That will be the initial install. After that, I'll consider a separate lithium install to run the AC side of the coach, and eventually solar. There's a YouTube and site out there called 5112 by Mike Mas that has the AC, DC systems separated, very interesting approach. Anyhow, thank you so much for taking the time to reply to my post and for your recommendations. JD 2012 Monaco LaPalma 32SBD gasser Link to comment Share on other sites More sharing options...
CAT Stephen Posted May 17 Share Posted May 17 JD, The EP4 Inverters with integrated solar controllers are an excellent choice and are one of the most cost efficient combined systems on the market. EP4 products are also very highly rated by Will Prowse (YouTube Solar and Electrical Systems SME). Mike Mas is the undisputed expert in grid tied and off grid electrical systems, and has the best reputation in the RV electrical industry as a master of the trade. So you are in the following the best source in the industry. I also used a Renogy DC-DC charger previously. It is a great product that does the job. Keep in mind that since it does not have an isolated ground, any shunts that you have installed will not see an accurate state of charge for Lithium batteries because the electrical flow between the house and the chassis electrical systems can't be accurately measured due to a lack of an isolated ground within the Renogy DC to DC charger. This margin of error will only occur when you enable the Renogy DC to DC charger Link to comment Share on other sites More sharing options...
JDPenn Posted May 18 Author Share Posted May 18 On 4/27/2024 at 1:48 PM, timaz996 said: If sizing is an issue look up Lossigy 200 ah batteries. I have four for the last two years and love them full timing. Thanks Tim. 17 hours ago, CAT Stephen said: JD, The EP4 Inverters with integrated solar controllers are an excellent choice and are one of the most cost efficient combined systems on the market. EP4 products are also very highly rated by Will Prowse (YouTube Solar and Electrical Systems SME). Mike Mas is the undisputed expert in grid tied and off grid electrical systems, and has the best reputation in the RV electrical industry as a master of the trade. So you are in the following the best source in the industry. I also used a Renogy DC-DC charger previously. It is a great product that does the job. Keep in mind that since it does not have an isolated ground, any shunts that you have installed will not see an accurate state of charge for Lithium batteries because the electrical flow between the house and the chassis electrical systems can't be accurately measured due to a lack of an isolated ground within the Renogy DC to DC charger. This margin of error will only occur when you enable the Renogy DC to DC charger Thanks CAT. Link to comment Share on other sites More sharing options...
