Service light on Allison only at full throttle
Go to solution Solved by jacwjames,
The title sums up my issue.  1998 Monaco Windsor.  The "service" indicator comes on in the shift pad but only at full throttle.  I have a mechanical engine, no ecm on my engine.  Just noticed it yesterday, everything seems to be shifting ok, but the light keeps coming on.
Any ideas?
43 minutes ago, Mark Underhill said:
Not sure how to check them.
On mine I press the Up & Down arrows twice and it will start displaying codes.  You'll see D1 and then the code, I think it will display 4 codes.
  • Thanks 1
What model transmission do you have?
I found this post on IRV2 regarding TPS on a rig of your vintage (maybe).
https://www.irv2.com/forums/f123/throttle-position-sensor-527263.htmlts2973
Here's a link to trouble shooting manual, to a search for "Throttle Position Sensor" and it will show you where it is mentioned https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://yardtruck.com/wp-content/uploads/2020/04/MD3060_Troubleshooting_Manual.pdf&ved=2ahUKEwjRjM2tuveFAxXa4skDHdoiAQ8QFnoECBoQAQ&usg=AOvVaw35SPf4_ie7W1nUJnK12QdE
  • Like 2
