Kenster Posted May 21, 2024 Posted May 21, 2024 (edited) Has anyone added a clean-out port to their black tank? I want to add a 2 inch threaded ABS connector to my black tank. Any suggestions on epoxies or other adhesive sealants? Am I correct in assuming the black tank is made from abs plastic? Edited May 21, 2024 by Kenster
Steve Maurer Posted May 21, 2024 Posted May 21, 2024 I replaced my black water tank using these fittings. I had to buy entire kit but cost is not bad. check out RecPro sku: RP-FWKIT
JOHN McCLURE Posted May 21, 2024 Posted May 21, 2024 If you can, swing up the side panel and see if there is plenty of room above your black tank ( as there is on my 05 diplomat ). I cut a 8 in square hole and used the piece of plywood as a plug and screws with wing nuts. It is easy to take a hose and flush out the tank. end of any problems.
Kenster Posted May 21, 2024 Author Posted May 21, 2024 I'm assuming you insert the screws from the inside pointed out, and apply a little silicone between the tank and the wood?
