Jeeper44 Posted May 26 Share Posted May 26 Many years ago the flooring in my 2005 Knight were replaced with a laminate wood. At that time they replaced the teflon/plastic pieces on the bottom of the slides that would normally run on carpet over to a product that looks a lot like felt. This has since deteriorated so in many places the slide floor is rubbing on the wooden floor when retracting/extending. The floor in the living room has some pretty good scratches from it. I would like to know the recommended solution to this issue. If I should replace it with the same felt type material, what product should I use? I don't think its regular felt as that wouldn't hold up very long at all. I don't have any pictures of what they used, but I can get some if that would help. - Andy Link to comment Share on other sites More sharing options...
Paul J A Posted May 27 Share Posted May 27 I would contact https://eliternr.com/120-2/ . Link to comment Share on other sites More sharing options...
