CapnDean Posted November 14, 2020 Share Posted November 14, 2020 2008 Camelot 42PDQ. The outside tv does not receive a signal from the antenna. PO stated that the window above it was removed in order to install a fridge and it hasn’t worked since. He figured that the cable got monkeyed up in the process. i need to remove the tv in order to access the cable. Anybody know what holds that rascal in there? I tried to slide it straight up to dislodge any slide in hooks, no joy. There is no access to any screws that I can see? Anybody? Link to comment Share on other sites More sharing options...
Gary M Posted November 15, 2020 Share Posted November 15, 2020 (edited) My screws were accessed under sink. Loosen then slide up. Previous coach not current one. Edited November 15, 2020 by Gary M Link to comment Share on other sites More sharing options...
CapnDean Posted November 15, 2020 Author Share Posted November 15, 2020 My coach has a sofa along the interior wall “behind” the TV enclosure. There’s no access unless hidden behind sofa Link to comment Share on other sites More sharing options...
Gary M Posted November 16, 2020 Share Posted November 16, 2020 1 hour ago, CapnDean said: My coach has a sofa along the interior wall “behind” the TV enclosure. There’s no access unless hidden behind sofa How about some pictures. From all external TV’s I’ve seen, not sure who makes the enclosure, but all Ive seen have a keyhole mounting. Also they had some sort of access from inside. I would love to be there to see your setup. Link to comment Share on other sites More sharing options...
CapnDean Posted November 16, 2020 Author Share Posted November 16, 2020 Keyhole mounting? Only way that there could be rear access on mine would be to remove the sofa. There MAY be a panel or a hatch that I can’t see. Link to comment Share on other sites More sharing options...
Gary M Posted November 16, 2020 Share Posted November 16, 2020 4 hours ago, CapnDean said: Keyhole mounting? Only way that there could be rear access on mine would be to remove the sofa. There MAY be a panel or a hatch that I can’t see. Well I hope someone with a coach like yours responds. Link to comment Share on other sites More sharing options...
CapnDean Posted November 17, 2020 Author Share Posted November 17, 2020 Thanks Gary; I removed the sofa and found the access panel. what a pain! But I know have a working external tv YAY! Link to comment Share on other sites More sharing options...
Gary M Posted November 17, 2020 Share Posted November 17, 2020 2 hours ago, CapnDean said: Thanks Gary; I removed the sofa and found the access panel. what a pain! But I know have a working external tv YAY! Alright!!!! Link to comment Share on other sites More sharing options...
