Posted
Hi All,
I searched the forum a bit, but couldn’t find anything and I’m hoping someone might be able to help. I can’t lift the under-bed engine access hatch. I see a latch on each side, but after unlocking them it still won’t budge. There are no visible screw heads, but I suppose they could be buried in the carpet. Any guidance is appreciated.
(97 Exec, side radiator)
Guest Dive Dive
Posted
I don’t have the latches that you do but I will tell you that when I was trying to lift mine I greatly underestimated the seal that hatch has.  It took quite a bit of lift to crack it loose.
Posted
Like the others have said...  undo the latches and make sure you are pulling up on the part that actually moves.  On mine there is a storage compartment in front that does not come up.  It might help having someone lift on each side, but mine opens from just one side.  Take a picture if you don't figure it out.
Posted
Thanks all. I have it in for some services and they couldn’t open it either. They’re worried about breaking the lid. I’m going to suggest that they check around the edge with a magnet for screws, and if they don’t find any, go ahead and get the pry bar. My latches look different than those pictured above, and there is also a metal ring/handle on top (toward foot of bed) to pull up on.
Posted
16 hours ago, CaliCruiser said:
Hi All,
Soak them with WD 40.  Bet they are all gunked up underneath.
