Bill C Posted May 11, 2021 Share Posted May 11, 2021 (edited) My engine voltage gauge has always read high, around 18 volts, although now it looks like it is actually reading off the gauge so high. It's hard to get in there and measure the actually voltage on the gauge, but the voltage to the batteries, at the batteries, when the engine is running, is about 13.5v to 14v DC, which I think is fairly normal when charging. The voltage at the gauge with the key on, but the engine not running, is about 16, and about 18+ when the engine is running, so I think everything is normal except the gauge. Is this gauge adjustable (i.e. is there a reostat that I can tweek to lower the reading? I'm thinking of just buying a digital voltage gauge that would plug in to my cigarette lighter socket, and use it. Anyone see an issue with this? I guess I can also just buy any 2" voltage gauge to replace this one, right? I'm thinking a digital one would be easiest to read. Thanks, Bill Edited May 11, 2021 by Corkman Link to comment Share on other sites More sharing options...
John Haggard Posted May 11, 2021 Share Posted May 11, 2021 46 minutes ago, Corkman said: My engine voltage gauge has always read high, around 18 volts, although now it looks like it is actually reading off the gauge so high. It's hard to get in there and measure the actually voltage on the gauge, but the voltage to the batteries, at the batteries, when the engine is running, is about 13.5v to 14v DC, which I think is fairly normal when charging. The voltage at the gauge with the key on, but the engine not running, is about 16, and about 18+ when the engine is running, so I think everything is normal except the gauge. Is this gauge adjustable (i.e. is there a reostat that I can tweek to lower the reading? I'm thinking of just buying a digital voltage gauge that would plug in to my cigarette lighter socket, and use it. Anyone see an issue with this? I guess I can also just buy any 2" voltage gauge to replace this one, right? I'm thinking a digital one would be easiest to read. Thanks, Bill Your thinking correctly Good viable options All of them personal choise Link to comment Share on other sites More sharing options...
waterskier_1 Posted May 11, 2021 Share Posted May 11, 2021 I think it is fairly safe to say that your dash gauge is reading high. These are not super accurate gauges. Mine reads high, but not that high. If you have read voltage at the battery/alternator, then you can say that the dash voltage is not going to be higher. It is a matter of which gauge is most accurate. Almost any would be more accurate than the dash gauge. Personally, I've taken a mental note of where the gauge reads, when it's at nominal 12.5 Volts and then when it's charging at around 14 Volts, and just use the existing gauge. It is not likely to further deteriorate, without gross failure (won't read at all). Link to comment Share on other sites More sharing options...
