Stevve Posted June 21, 2021 Share Posted June 21, 2021 Can someone tell me how to remove the center hub cap on the tag axle to check oil level? Accuride’s 22.5. Thanks, Link to comment Share on other sites More sharing options...
Frank McElroy Posted June 21, 2021 Share Posted June 21, 2021 7 minutes ago, Stevve said: Can someone tell me how to remove the center hub cap on the tag axle to check oil level? Accuride’s 22.5. Thanks, The end caps pull off. But sometimes with some difficulty. Look closely and you will see a small area where you can fit a short flat blade screwdriver in between the end cap and the round cylinder holding on the end cap. I find this is the easiest way to pop off those end covers. Link to comment Share on other sites More sharing options...
Vettman66 Posted June 21, 2021 Share Posted June 21, 2021 Putting it back on is more of a challenge Link to comment Share on other sites More sharing options...
Stevve Posted June 22, 2021 Author Share Posted June 22, 2021 Thanks, hub caps off and back on. Oil level OK! Link to comment Share on other sites More sharing options...
96 EVO Posted September 1, 2021 Share Posted September 1, 2021 On 6/20/2021 at 6:07 PM, Vettman66 said: Putting it back on is more of a challenge Only challenging to get it back on without little dents all around the perimeter 😉! Link to comment Share on other sites More sharing options...
