Headlights Stuck on High Beam
klcdenver
My headlights are stuck on high beam and low beams are not on at all. Fuses and relays in electric bay on drivers side all check good and have been swapped out. I can hear relay inside dash click when I press the high low beam on smart wheel. High beams flash when the Flash button on smart wheel is pressed. All the other functions on smart wheel are working. I removed all power and restored and same results. Could it be the manual switch on the dash? Good ideas appreciated.
2007 Diplomat 40SKQ
Thanks,
Kenneth
