Testdepth Posted July 27, 2021 Share Posted July 27, 2021 96 Windsor, C8.3/275hp. I have a hydraulic fan motor that the regulator is not functioning correctly. When I got the coach it was leaking pretty badly and would cycle fan speed somewhat erratically, but was essentially working other than the leak. (a small puddle where ever I stopped). I drained the system, the ATF was a little dark but wasn't burned and removed the control valve unit. disassembled it and found one smashed O-ring one machined opening that was empty and another o-ring in good shape. The machined opening appeared to be for a crush washer or similar type seal. I replaced the 2 O-rings that were there cleaned the whole unit and reinstalled. the leak stopped but now the regulator works even worse than before. I can find no mfg. name on the unit anywhere and no one at any of the truck places near me that knows anything about them. Is there anyone on the forum that knows anything about these or a former Roadmaster employee that might have some documentation on this crazy unit? I'm pretty certain it just need the correct set of seals etc and it would be back in business. I would appreciate any help/knowledge anyone could provide. Mike Link to comment Share on other sites More sharing options...
Jim McFarland Posted July 27, 2021 Share Posted July 27, 2021 Call Northwest RV Supply at 866-678-7467 and talk to Niabi. She and the other employees are very helpful. It is my understanding that the purchased all the left over parts from REV before Orgeon was shut down. Their email is nwrvsupply.com Jim M Link to comment Share on other sites More sharing options...
Testdepth Posted July 28, 2021 Author Share Posted July 28, 2021 Thank you Jim. I will give them a call. mike Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted July 28, 2021 Share Posted July 28, 2021 Call Scott Zimmer former Roadmaster chassis expert at Source Manufacturing in Eugene, Or at 541-935-0308. He will help you. Chuck B 2004 Windsor 1 Link to comment Share on other sites More sharing options...
waterskier_1 Posted July 28, 2021 Share Posted July 28, 2021 I have some info on the wax control valves which I thing you have - my 97 Dynasty did. What is it not doing or doing wrong? If you referred the lines to it that would cause problems. Are you sure it's the controller and not the motor? Link to comment Share on other sites More sharing options...
Paul A. Posted July 28, 2021 Share Posted July 28, 2021 17 hours ago, Testdepth said: 96 Windsor, C8.3/275hp. I have a hydraulic fan motor that the regulator is not functioning correctly. When I got the coach it was leaking pretty badly and would cycle fan speed somewhat erratically, but was essentially working other than the leak. (a small puddle where ever I stopped). I drained the system, the ATF was a little dark but wasn't burned and removed the control valve unit. disassembled it and found one smashed O-ring one machined opening that was empty and another o-ring in good shape. The machined opening appeared to be for a crush washer or similar type seal. I replaced the 2 O-rings that were there cleaned the whole unit and reinstalled. the leak stopped but now the regulator works even worse than before. I can find no mfg. name on the unit anywhere and no one at any of the truck places near me that knows anything about them. Is there anyone on the forum that knows anything about these or a former Roadmaster employee that might have some documentation on this crazy unit? I'm pretty certain it just need the correct set of seals etc and it would be back in business. I would appreciate any help/knowledge anyone could provide. Mike Please consider calling Scott as Chuck B has suggested. Link to comment Share on other sites More sharing options...
Testdepth Posted August 29, 2021 Author Share Posted August 29, 2021 I did call Scott and had a nice conversation with him. Based on his comments that the regulator itself is a very low failure item I decided to pull the regulator back off to ensure I hadn’t messed it up. I did and found the main piston apparently had some crud in it that I didn’t find before or was in a hose. I recleaned and assembled with lots of atf and made sure everything was smooth and free. The problem appears to be resolved. 1 Link to comment Share on other sites More sharing options...
