Pepperell Posted August 3, 2021 Share Posted August 3, 2021 (edited) I just lost 12v power to the matrix system. No lights, no ability to use slide outs, switch on Aquahot, turn on thermostats, water pump. The matrix panel draws its power from the rear run box via 2/0 cable. The BigBoy is humming. I switched off the house and engine batteries then turned them back on, got a clack sound from the BB aftrer a few seconds. Still no power to the matrix. We are full timers. We’re screwed. How can I jumper 12v to the matrix? HELP!!! Never mind. Idiot owner must have accidentally bumped the salesman switch. I’ve never used it since I bought the coach. Edited August 3, 2021 by Pepperell Link to comment Share on other sites More sharing options...
cbr046 Posted August 3, 2021 Share Posted August 3, 2021 As Forrest Gump would say: "It happens" Glad you found it, - bob Link to comment Share on other sites More sharing options...
Pepperell Posted August 3, 2021 Author Share Posted August 3, 2021 It was an hour of my life I’d like to have back! Link to comment Share on other sites More sharing options...
Gary_Curtis Posted August 4, 2021 Share Posted August 4, 2021 (edited) This happened to me and the Solenoids were the problem...they were burnt badly. I bypassed them to get the slides and 12V house power back to the matrix. It worked so well that I have yet to switch them back after a year. I got replacement Solenoids off of Amazon for $35 each. I'll get to it one of these days. It would be nice to use the +12 volt cut-off switch in the stairwell at night. Before you reach in there you need to disconnect the batteries. Then take the wires from the right side of the Solenoid and move them to the left side. Keep the wires connected to the black "High-Amp" circuit breakers. Don't over tighten the Solenoids or the black plastic will crack...ask me how I know. You need to get some compressed air and blow out your rear run box. things are pretty dusty in there. Edited August 4, 2021 by Gary_Curtis caution to disconnect battery Link to comment Share on other sites More sharing options...
Pepperell Posted August 4, 2021 Author Share Posted August 4, 2021 Thanks Gary! I’ll be inflating tires soon so I’ll clean up things then. Link to comment Share on other sites More sharing options...
