mpgast Posted August 10, 2021 Share Posted August 10, 2021 I have old Fantastic fan. With the good fuse all the way in and locked it will not get any power. With the fuse held in lightly it does get power. Anyone have a idea what might be going on? Link to comment Share on other sites More sharing options...
John Haggard Posted August 10, 2021 Share Posted August 10, 2021 29 minutes ago, mpgast said: I have old Fantastic fan. With the good fuse all the way in and locked it will not get any power. With the fuse held in lightly it does get power. Anyone have a idea what might be going on? Fuse socket needs replaced Your either making contact or your not Play around with the latch Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted August 10, 2021 Share Posted August 10, 2021 The spring in the fuse holder has been compacted down. Reach into the fuse holder with a pair of long nose plyers and pull the spring up a little bit. That will streach the spring enough to make contact with the fuse. Chuck B 2004 Windsor 1 Link to comment Share on other sites More sharing options...
ko7pjim Posted August 11, 2021 Share Posted August 11, 2021 On 8/10/2021 at 5:34 AM, John Haggard said: Fuse socket needs replaced Your either making contact or your not Play around with the latch If by accident a shorter fuse was used, you may not be able to get it out. If you are careful, you might be able to use a small enough wooden dowel with a drop of super glue to stick to the fuse and pull it out. 1 Link to comment Share on other sites More sharing options...
