Bob Schmeckpeper Posted August 28, 2021 Share Posted August 28, 2021 We have a 2001 Diplomat. The slides are gear driven. My back wardrobe slide is a worm gear operated system. The worm gear is not meshing like it should and its damaging one of the teeth. Is there a way to tighten up the gears so they mesh better? Here is a picture of the worm gear. The teeth are barely touching. When I deploy the slide I'm getting a loud snapping noise when a certain tooth jumps a gear. Link to comment Share on other sites More sharing options...
Jim Bob Posted August 28, 2021 Share Posted August 28, 2021 Is that a set screw on each of the gear collars? You might be able to adjust the alignment a little if they are. No actual experience with this... just a guess. Link to comment Share on other sites More sharing options...
Gary Cole Posted August 28, 2021 Share Posted August 28, 2021 Those gears do have far to much lash. Would have been a better design if they had of used dissimilar materials in the pair since they run dry. Been thinking about using a lubricant which would not attract dust and grime. Maybe something used on woodworking tools. Link to comment Share on other sites More sharing options...
jacwjames Posted August 28, 2021 Share Posted August 28, 2021 Here's a recent post on IRV2.com that goes through this very problem. https://www.irv2.com/forums/f115/bedroom-slide-bevel-gears-548494.html FFrank did find a replacement gear but had to have the pin locations drilled. Finding this before it completely fails will provide enough time to fix and not leave you stranded somewhere. Good Luck Link to comment Share on other sites More sharing options...
Bob Schmeckpeper Posted August 28, 2021 Author Share Posted August 28, 2021 (edited) James Thank you so much. Were out till mid October. Got to figure out how to keep it going till then. Now I can at least start chasing the gears down. I need to also try to figure out how to get the gears a little closer together. Just riding on the the edge were they can jump when it gets worn down is not a good thing. Maybe my machinist friend can help with that. Again a big thank you. Bob Ok, so I can't read. Lol When my wife read it she found the fix that I was working on. Edited August 28, 2021 by Bob Schmeckpeper Added content. Link to comment Share on other sites More sharing options...
jacwjames Posted August 28, 2021 Share Posted August 28, 2021 From your picture I cannot see any type of adjustment. Unless there are ways to shim the gears or shafts it will be difficult. In the link that I provided the gears that were purchased did not have the split pin holes, they had to be drilled. With proper measurements you might be able to adjust these holes to take up some of tolerance. I guess one thing that would help is to lubricate on an annual basis, a little grease would go a long way. Another thought If the gears have keyways you might be able to install a set screw instead of a split pin. The set screw would allow you to move the gears to properly align them. This application is not that severe so I would think a set screw would be sufficient to hold the gears in place. Coupled with annual inspection and lubrication I think it would work. 1 Link to comment Share on other sites More sharing options...
Gary M Posted August 28, 2021 Share Posted August 28, 2021 Looks like the nylon spacer has worn allowing shaft and gear to back away. Is that a set screw outside the box that u could loosen and move shaft with gear closer? Link to comment Share on other sites More sharing options...
Gary Cole Posted August 28, 2021 Share Posted August 28, 2021 That is a good observation Gary. The vertical axis of the top gear is in line with the lower gear indicating that it should be shimmed and not the lower gear. You 've probably seen a few things in your line of work. 🙂 Link to comment Share on other sites More sharing options...
Gary M Posted August 28, 2021 Share Posted August 28, 2021 5 hours ago, Gary Cole said: That is a good observation Gary. The vertical axis of the top gear is in line with the lower gear indicating that it should be shimmed and not the lower gear. You 've probably seen a few things in your line of work. 🙂 I am an ex machine mechanic for lumber mills. Dealt with many miter gear issues. Also ex cross country truck driver, security guard, jack of all trades and master of none.😜 1 Link to comment Share on other sites More sharing options...
Bob Schmeckpeper Posted August 29, 2021 Author Share Posted August 29, 2021 8 hours ago, Gary M said: Looks like the nylon spacer has worn allowing shaft and gear to back away. Is that a set screw outside the box that u could loosen and move shaft with gear closer? No set screw, just a pin. Picked up a washer today, to take up the slack, wouldn't you know it, its just a tad to thick. Will try a 2 x 4 tomorrow. Till I can get a file or grinder. Got to come up with a redneck fix till we get home. Link to comment Share on other sites More sharing options...
