Joe Lee Posted September 1, 2021 Posted September 1, 2021 Hi All - I have an exhaust fan in the engine bay of my 1996 Crown Royale Signature. I replaced the fan but the wire going to the fan doesn’t seem to have power. Does anyone know if there is a power switch for this fan? I expected the wire to be energized when I started the coach, but no luck yet. Any help or ideas are appreciated! Joe
jacwjames Posted September 1, 2021 Posted September 1, 2021 May be controlled by a thermo switch, when the engine bay gets hot it turns on. You might try bringing it up to temperature.
Joe Lee Posted September 1, 2021 Author Posted September 1, 2021 Great idea! I will do as you recommend. Thanks!
Marty K Posted September 1, 2021 Posted September 1, 2021 As mentioned it is controlled by a temperature control, it looks like a high limit switch used in furnaces. The temp setting can be changed by rotating the setting. Its under your bed. Marty
Joe Lee Posted September 1, 2021 Author Posted September 1, 2021 Great! Thanks. I will go look for it.
