Patrick Posted September 28, 2021 Share Posted September 28, 2021 My adjustable pedals don’t move and are in an uncomfortable position. Can someone advise me how to troubleshoot this system and identify the reason for non-operation? When I toggle the switch nothing happens, no sound, no movement. I’m not sure where to start. Is there a way to manually adjust the position of the pedals as I doubt I will alter them very often once I find a sweet spot? Thanks for your help! Link to comment Share on other sites More sharing options...
Dr4Film Posted September 28, 2021 Share Posted September 28, 2021 Did you check the 12 VDC Fuse to see whether it has failed or not? Mine is in the Front Run Bay on the large electrical panel. Link to comment Share on other sites More sharing options...
Patrick Posted September 28, 2021 Author Share Posted September 28, 2021 1 hour ago, Dr4Film said: Did you check the 12 VDC Fuse to see whether it has failed or not? Mine is in the Front Run Bay on the large electrical panel. Yes. Fuse checks out ok. Link to comment Share on other sites More sharing options...
Dr4Film Posted September 28, 2021 Share Posted September 28, 2021 Then next would be to check if you have 12 VDC power at the control switch that runs the motor in and out. Link to comment Share on other sites More sharing options...
