Guest derylehinson Posted October 26, 2021 Posted October 26, 2021 The exterior mirror glass has come loose on my 2011 Dipolmat, and shakes while driving. I have it supported with duct tape until it can be repaired. Any info on how or where to get it repaired will be appreciated.
GregOlson Posted October 26, 2021 Posted October 26, 2021 Well. I have the same problem. And instead of trying to find a replacement ($900.00) or around that figure, I took my mirror off and removed all the pieces. I found that the mirror base frame inside the outside housing, was broken off the plastic. I used JB weld to fix the issue and it only lasted a couple months. I am going to have to try and use a better adhesive material next time.
Dwight Lindsey Posted October 26, 2021 Posted October 26, 2021 Deryle: What mirror do you have? In earlier coaches, the mirrors are probably RAMCO or VELVAC. In a 2011 which I guess was Navistar era, I have no clue. You should be able to find out by looking at the mirrors, or by looking at your build sheet or RV Data Card if you have them. I have RAMCO mirrors. I bought a new lower convex mirror glass, just the glass, not the whole mirror, from RAMCO: www.ramco-eng.com My replacement lower convex glass was SNP-GLS171-KIT. It came with a snap on skirt, a small manual mechanism and screws.https://shop.ramco-eng.com/collections/mirror-parts/products/snp-gls171-kit $34. Worked great. If you have a RAMCO, as I do, you should call them, perhaps send them a picture of your mirror and they can guide you to the replacement part you need. Dwight
GregOlson Posted October 26, 2021 Posted October 26, 2021 I have this kind. Dynasty 2002-2005: RV Motorhome Mirror, Driver Side, Chrome, 14 inch Arm, Velvac 715283-4 (rvpartscenter.com) Most likely not the same one you have.
Guest derylehinson Posted October 26, 2021 Posted October 26, 2021 Mine are Ramco . The mirrors are not broken, but they shake. You can tell the are loose in the frame. Probably glue has come loose that holds them to the adjustment Motor. I will contact Ramco, maybe they can help. Thanks. D.H.
Dwight Lindsey Posted October 26, 2021 Posted October 26, 2021 Deryle: My lower convex fisheye mirror was also loose and rattling. One day it blew off while going down the road. The replacement kit worked perfectly. The kit is more than the mirror, it includes the piece the mirror attaches to. Dwight
Gary Cole Posted October 27, 2021 Posted October 27, 2021 Ramco has a how to mirror replacement guide on their website with pictures. Could be used to fix a loose mirror. I did doubled up on VHB tape which is used to secure the mirror to the base.
eddie4ne Posted October 27, 2021 Posted October 27, 2021 The driver mirror became loose for us. We discovered that the bracket that held it had broken on one side. A piece of double sided gorilla tape did the trick. Is still holding about 3 years now.
seadoo200hp Posted October 27, 2021 Posted October 27, 2021 Drivers side fell off years ago (2014) and now passenger fell off in September. This is my 2nd replacement and Ramco can usually tell what kit you need by your year and model. $34 was the price but brace yourself for shipping...........$27 in my case for Colorado! I saw units on E-bay (with free or low shipping) but decided the factory for this one. I plan on using Gorilla tape which held up the temporary blind spot mirror purchased from Wal-Mart while on last trip. Ramco's phone number is 574-266-1455
OhReally Posted October 27, 2021 Posted October 27, 2021 Auto body shop or RV collision repair deal with this kind of thing all the time. Take yours to them after you call for an appointment. Also, beware of duct tape. If it's on your paint, it will take paint off when you remove it. Anywhere else, it will leave all of its adhesive on the coach after being sun drenched for a short while. -Jamie
Guest derylehinson Posted October 28, 2021 Posted October 28, 2021 Thanks to all of you, that replied to my post. I contacted Ramco. They were very helpful. Told me how to remove my glass. I found the motor had some play in it. A new one is on order. Hope this solves problem. Thanks to everyone.
Gary Cole Posted October 28, 2021 Posted October 28, 2021 (edited) On the topic of mirrors. If you snag a Ramco mirror on something and break it off that can be fixed by filing the two faces flat and tapping both pieces with a 3/8 pipe tap. I used a stainless steel high pressure nipple to join the pieces however I suppose any non corrosive metal would suffice. Edited October 28, 2021 by Gary Cole
