jfasano88 Posted November 17, 2021 Share Posted November 17, 2021 My left brake lights and left turning not working. Bulb is good. I posted my brake and left turn not working. I forgot to post my info john 2009 Camelot 42’ kfq Link to comment Share on other sites More sharing options...
Skipjack Posted November 17, 2021 Share Posted November 17, 2021 I had the same thing, and found out I had a bad relay. My relay box was in the front curb side front compartment. You can get these relays from Amazon (Omron12077866 is the same as the Tyco) 1 Link to comment Share on other sites More sharing options...
jfasano88 Posted November 17, 2021 Author Share Posted November 17, 2021 I posted my brake and left turn not working. I forgot to post my info john 2009 Camelot 42’ kfq Which relay I don’t understand Link to comment Share on other sites More sharing options...
Jim McFarland Posted November 17, 2021 Share Posted November 17, 2021 If your coach is like mine (2009 Monaco) is have rear light fuses in the very rear compartment on the passenger side. Good luck in finding your problem. Safe travels. Jim Link to comment Share on other sites More sharing options...
Skipjack Posted November 18, 2021 Share Posted November 18, 2021 If you zoom in on my first picture, you will see the names for each relay. the fist picture is the cover to the relay box there are also corresponding fuses in there as well Link to comment Share on other sites More sharing options...
jfasano88 Posted November 18, 2021 Author Share Posted November 18, 2021 My right brake and turning lights work fine. Are the left and right on a separate relays. john 2009 Monaco Camelot kfq Link to comment Share on other sites More sharing options...
Larry Laursen Posted November 18, 2021 Share Posted November 18, 2021 John, Your fuses for the turn signals on the 2009 are in the rear passenger side compartment. There is a plastic box with them inside. The pictures by Kevin are of a 2003 Neptune which are correct for that model and year. However, Monaco relocated them in 2008-09 to the rear. I don't have a picture. Link to comment Share on other sites More sharing options...
jfasano88 Posted November 19, 2021 Author Share Posted November 19, 2021 Thanks I looked into the the rear capartmet where the big boy is located. I found fuses but none of them related about brake or left turn. john 2009 Camelot kfq Link to comment Share on other sites More sharing options...
